FreeBeeTony
- May 15, 2002
- 3,997
After replacing the water pump on my Mercruiser 165 outdrive I noticed that the alignment of the shifter is off. When in forward the shifter should be facing directly forward. Its off to the port side. Question is this: I already filled the outdrive with fluid! If I don't remove the vent screw, will the vacum be strong enough to allow me to drop the lower half so I can adjust the position of the shifter w/o making a mess? I don't think I have to totally seperate the two halves, the shifter seems to be able to be lifted somewhat. Thanks in advance for the help.
