kblackav8or
- Oct 26, 2013
- 17
I pulled the lower on the mystery inline to rebuild the water pump. I believe I pulled it off in forward gear. The lower gear shift shaft has no resistence, i.e. doesn't feel like it is moving anything now. It is definitely in gear. I moved the shaft on the lower into the middle (neutral position) but it doesn't feel like I shifted anything. Same with the upper shift lever. What did I do wrong?
