Shift interuptor problem?
peterm
1987 Mercruiser I/O 5.7L Alpha One in water. Starts and runs fine. Will shift into forward but stalls when shifting out of forward or into reverse even when fully warmed up. New starter, coil, dist. cap, rotor, ign. sensor. Had outdrive off to replace bellows. Does shift interuptor have any adjustment? Any other ideas?
Re: Shift interuptor problem?
Was the Lower Shift Cable replaced when this was done ?????<br /><br />If it Wasn't,<br />It Should have been...........<br /><br />If it Was,<br />Bob's Adjustment Should Fix the problem.......
