Shift Interupter Switch operation
levittownnick
'97 Johnson 150hp model J150EXEUE S/N G04209751.<br />The switch is operational but the operating mechanism does not activate the switch. I don't understand what makes this assembly move up to activate the switch. Is the switch active in the neutral position up until the engine is in gear or just during the transition from neutral to gear? (I have dissesembled the shift linkages and lubricated the parts. No binding was observed.) It appears that the attachment point of the shift cable must rise to activate the switch but I don't see how.
Dhadley
Re: Shift Interupter Switch operation
It works when you shift out of gear into neutral. <br /><br />Good luck!
levittownnick
DHADLEY thank you.<br /> IF I understand correctly, this switch is only activated from gear to neutral. The force applied from the shift cable in oppisition to the shift mechanism, causes the lower pin assembly to slide up momentarily operating the shift switch.<br />Again I would like to thank DHADLEY and iboats.com.
