The last time I was on the lake and was shift into forward then the boad not moving and the engine run (RPM are go up) has to full back to neutral then forward again do that untill it go (maybe 5 to 10 time) But the Reverse are work fine. With your experience what will go wrong with it? Transom Shift Cable? Lower or Uper unit?
*** 1990 OMC Cobra Stern Drives ***
Last week I check it, start the engine shift to forward and I can here the sound like the gear in lower unit are not fully engage, check it with the engine off shift to forward it dose engage.
I want to Disassemble the stern drives to check it out, I do need help is there some think I should know before I disassembly it? or How to? Or you have the manual of the stern drives I can use?
Thank you
Tam
Thank you
Tam
