badognobisc
- Jun 17, 2009
- 22
I installed a new shift cable for a gm 5.7 liter and a alpha 1 gen 2, year 2000 the other day. I was on the back side threading it and the neighbor was in the boat to help feed and direct. He said could not see it and I felt pressure as I pushed and pulled a little. Some how the cable fed into the flex plate/coupler. We worked on trying to extract it for a few hours unsuccessfully.
I can feel a housing with a small opening at 11:00 and 7:00 o'clock but cant get a light and mirror back there to see the initial feed point. I did cut off the remaining cable, then measured it. What is stuck still is about 2 inches past the flex plate (not sure of the exact term) . I am looking for advice to remove and/or distance from the flex plate to the ujoints/spline drive. I cut enough off that there is a 4 inch tail sticking out, wasn't sure if this was a dead area down to the drive shaft.
I have a feeling I am going to have to pull the motor to extract it. Any advice or recommendations that may save me from pulling the motor are appreciatted. I tried to search for a picture or specs of distance inside but did not see anything.
Still can't believe I could hit that one special point to feed it into that opening first time out and that this could happen. The space feels about a finger tip of an opening. It feels like there are only a few openings around the perimeter like a triangle flex plate.
Thanks for help.
Thanks for help.
