keithm1961
- Jan 29, 2010
- 46
Had the boat out for a great weekend, all went well with the newly rebuilt 85 horse Johnson. 2 Minor mishaps I'd like to ask about. I checked shift cable adjustment while hooked to the hose, never letting engine go above idle, all seemed fine. In the water I had the same result for awhile, after a couple of hours running, It wouldnt shift into reverse, the movement of the shift lever is smooth so I re adjusted the cable and it worked great, for awhile. I finally changed the length of the shift rod 1 turn and that seemed to solve it. The cables are old, should I replace them just so I know whats up. Also what is the proper way to measure and rout the cables. The cables I have on it are WAY to long, so they are looped under the motor well. I'd like to get the right length but the info I've found says once the measurements are made add 4 feet, that seems excessive.
The other problem is at full throttle the fuel bulb collapsed and killed the engine, I checked the vent on the tank and it was clear. I dissconnected the quick release at the tank the bulb stayed flat, when I reconnected it vented and the bulb went back to normal. It sounds like some kind of venting issue, any ideas.
Thanks
Keith
BTW the boat is a 15' 1974 ebbtide lakemaster
Thanks
Keith
