river rat 26
- Feb 4, 2003
- 85
I'm workig on a 75 85hp evinrude, motor became extremely hard to shift. I've got the prop shart & shift shaft out so far. Is there a way to bench test the shift assist cylinder? It is very hard to move the shift rod/piston in the cylinder. I haven't disassembled it yet, I guess I need to make a couple of spanners first. Are these available somewhere (assist cylinders) or rebuild kits? Is it likely that this could be my shifting problem? Oh yeah, I did ck all the outher components before removing the L/U, motor shifts the same running or off, have to pry up or smack down the linkage connected to top of shift rod. I'm guessing it's this assist cyl or the oil pump which I haven't gotten out yet.
