98 Merc 3.0 Alpha I, Engine SN 0L044623, Drive SN 0L178476
This is my second season with the boat and this is the first boat I've owned.
Noticed a few weeks ago when running the engine on the muffs in the driveway an oil sheen was on the water collecting where it ran into the grass. I stuck a bucket under the water exiting the boat and sure enough there was a visible sheen on the water. I knew the gimbal bearing needed to be changed so when the drive was off in the spring I replaced everything serviceable that is behind the outdirve with new Merc parts (shift cable, bellows, water hose, drive oil hose, shift shaft bushings, etc. I also dropped the lower unit and replaced the impeller.
Here is what I've done to try and diagnose where the oil is coming from. I drained the outdrive and pressure tested, held 14psi for over 24 hours. Went ahead and dropped the lower unit anyway and there was no evidence of oil where it shouldn't be. Just for the fun of it I replaced the shift shaft seals in the lower unit and the upper drive shaft seals under the impeller. The drive still help 14psi for over 24 hours. I also pulled the thermostat and you could see the sheen on the water under the thermostat.
The next thing I did was bypass the power steering cooler and there was still a sheen on the water exiting the boat. There is no water in the oil that I can tell from the dipstick. I'm out of ideas on where to go next. I have uploaded pics of the sheen thats clearly visible. .
I appreciate any help provided.
