she runns great
bluetop
I got that 65 mcculloch in the water after a bit of work and it runns perfect i hate to jinx it but it did it a 14 foot with a 45 hp electric start trailer every thing original put it the water and away she went no problems any one no of something i should look out for cause i d hate to reck somethin
Tom @ Buzzard Bluff
Re: she runns great
If you haven't replaced the waterpump impeller do it BEFORE you crank it up again!
Please share pics of the "electric start trailer" with us.
bluetop
Re: she runns great
sorry about that tom the motor was eectric start not the trailor lol but everything is oringanal
M
mrcrabs
Guest
Re: she runns great
Toms giving you good advice on the water pump, check it as they have a tendancy to just turn lose if they have set for a lenght of time and you don't want to fry your new toy.
Good luck and happy boating:)
bluetop
Re: she runns great
when they turn loose what do u mean its pressure fit correct and i guess it could crack to thanx guys
bluetop
Re: she runns great
if the auto bailer doesnt work is this a problem it seems as tho there is exhaust coming from the bailor that seems strange
Tom @ Buzzard Bluff
Re: she runns great
If an impeller starts disintegrating the pieces are pumped into the water tube and the waterjacket of the motor leading to blockages that that can cause heat to destroy it. Even should you be fortunate to discover the problem before the engine is cooked trying to get all the pieces out of all the blind passages in tube and waterjacket is one of the worst dilemmas one can encounter with old outboards. And that is why I always suggest that a new impeller is the very FIRST part to be replaced before spending other $ on a rehab. If you spend time and $ reviving an old motor and then allow a bad inpeller to cook it then everything you invested--both time AND $---is lost. It is the best, cheapest and---ultimately---the only insurance you can buy on an outboard!
You're motor is now 45 years old. Do you KNOW beyond any possibility of doubt that it has had a recent waterpump impeller replacement?
If the original impeller is still in place how long do YOU think 45 years old rubber can withstand repeated heat cycles, ozone deterioration and time?
bluetop
Re: she runns great
i hear ya loud and clear thanx guys appreciate the experience
