Shaft o-ring
cc67
I know the o-ring on the top of the drive shaft is supposed to keep water out of the powerhead, but is this really a problem? Has anyone experienced a failure from this?
Dhadley
Re: Shaft o-ring
It doesn't keep water out of the powerhead. It's job is to keep water off of the crank & driveshaft splines. It's still a good idea to keep those splines greased. In fact if you grease the splines yearly with a good lube you really don't need the O ring. I recommend both good grease and the O ring.
cc67
Re: Shaft o-ring
I always lube the splines when I install a shaft but I forgot to put a ring on and thought dang, I don't want to pull this thing again. Most of the older motors I've torn down lately don't have o-rings on the shaft.
Chinewalker
Re: Shaft o-ring
All you need is one time having a driveshaft rusted into a crankshaft to wish you had replaced the o-ring... It's a PITA if there ever was one...
- Scott
F_R
Re: Shaft o-ring
Heck yes, you need it. Ignore it and you will find the splines frozen and impossible to get apart next time. Worse yet, given enough time it will rust the splines out of the crankshaft and THAT is THAT!!
cc67
Re: Shaft o-ring
Went ahead and pulled the unit and put on the ring. I must be getting good at it as it only took me 20 minutes. :D
