Shaft length
Snerd
I am looking to buy a lower unit for my 1997 90hp force, I found one on craigslist from a 1995 120hp force and the guys says that its 14 inches which from what I have been reading this is not correct. If he can find the numbers off it can it be found from that or is there any other way? Thanks.
Frank Acampora
Re: Shaft length
That was a two part drive shaft. If the top part is 14 inches, then it fits a 20 inch transom and midleg. HOWEVER: if you still have your driveshaft, it will swap onto the coupler on the lower unit stub shaft and (here is where I am not too sure) if both lowers are Mercury bolt pattern, then the one you want to buy will fit.
HAV2FISH
Re: Shaft length
Are you looking for a 20 or a 25in shaft. I might be able to help. Just give me a private message.
Faztbullet
Re: Shaft length
1995-97 is the Merc/Force 3 jaw unit and 1998-99 is the 6 jaw unit. If you have a 1997 90hp it should be the Merc/force unit and the 2 piece unit will not bolt up.
Merc unit.......... Force unit
