Setting timing on 2008 Mercruiser 5.0 tks
mdaddy
Where can I find the procedure for the static setting of the timing on a 2008 Mercruiser 5.0 tks? Which wire to ground, etc... Thanks!
Serial#: 1A322719
Scott06
Factory manual is best place. A couple screen shots attached
procedure is at bottom of one
purple /white wire plug end on mine comes out of engine harness by shift interrupt wires on starboard side of intake.
ground the plug at end of purple white wire , set timing at 10 deg btdc… take ground wire off,
