Setting carb float on NS8B
IDFISHER
I had a previous post regarding my carb needle not seating properly so I ordered a carb kit with new float, needle, clip, etc. I'm just wondering if there are any precise measurements I need to consider when setting my float height or if setting it parallel with the carb body will be good enough.
IDFISHER
Thank you. I went with parallel and everything is seated, sealed and running good as new.
