yorab
Ensign
- Jul 6, 2002
- 960
Motor in signature with battery distributor ignition. I've always adjusted points by gapping. However, my Seloc says that it is more accurate to adjust points by testing for continuity while the timing mark on the disty pulley aligns with the timing bosses on the disty body. Is this a more accurate method? It seems that it would be, but I want to get some input from people who have tried this before. I can post a scan of the few paragraphs that describe this method if necessary.
Secondly, how tight does the eccentric point adjustment screw need to be before mounting the plate that holds the points? Thanks.
