Serpentine conversion
I have a v8 small block mercruiser with a bravo 2 outdrive. My issue is the water pump that is mounted on the front of the motor is not OEM and is causing problems. A OEM water pump is a serpentine setup so are there any conversion kits available or do I have to part and parcel everything out.
first, welcome aboard.
second, are you sure its not OEM?
post your serial number
