Serpentine belt not moving - lots of squealing
jabberw0cky
Boat:
2002 Tige 20V - V-Drive Inboard wakeboarding boat
350 Mag MPI Ski engine (see parts/diagrams here, if it helps: http://www.crowleymarine.com/mercury_parts/10508.cfm)
Background:
We've had squeeking noises coming from the serpentine belt on our engine intermittently for some time now. Running a bar of soap along the belt always quiets it down for a period, but then it comes back later. Yesterday I purchased a new belt to put on, and planned to do it while we were out on the water.
We went out last night, and the Engine started fine, we were out for about 30 minutes, pulled our son skiing without any problems. Turned off the engine, and filled two ballast bags on the port side in the V-Drive storage locker in preparation for wakesurfing (older bags, so maybe combined weight of about 600lb). When we next started the engine, it had a hard time starting, was turning over but not actually starting. Finally, when it did start, loud squealing sounds came from the engine compartment. When I opened up the engine compartment, I could see that the pulleys and belt were not moving, so the only thing moving was the crankshaft pully, but the serpentine belt was not moving with it, and this was the source of the noise. Turned off the engine, and let it sit for a second, and then tried again - with the same response. Loosened the serpentine belt, and moved each pulley by hand - all moved fine (2 idler pulleys, alternator pulley, water pump pully), except the seawater pickup pump pulley, which I was able to turn but with difficulty - which I thought was probably normal? Re-tightened belt and tried again, with same outcome, lots of noise and no movement. I removed the belt and put on the new one that I had purchased earlier that day. Tried again and this time the pulleys and belt moved, but still not quite at the speed of the crankshaft pulley, so still some squealing. Turned off engine and tried again and this time the same result, no movement of belt and lots of squealing. By this time I finally thought the crankshaft pulley is very hot, so let's let it cool down and try again. We waited 10 minutes, and I used a spray water bottle to spray the crankshaft pulley to try to help it cool down. Then we tried again and the same result. Finally, I called the water patrol and had them tow us back to the dock so we could pull it out of the water and go home (in a very bad mood). I emptied the ballast bags before getting towed over, of course. I figured at this point that probably what had happened was that the seawater pump impeller had burned up or something and was preventing the seawater pump from operating and rotating, hence the belt not moving and the squealing from the crankshaft pulley.
Once we arrived at the dock, I backed the truck down and put the trailer in the water. I then tried starting the boat one more time, figuring it wouldn't be any worse than before. Of course, at this point it started up just great, belt moved fine and all pulleys in sync. I let it run to operating temperature (about 175) and verified that it stayed there, and didn't overheat - so I assumed that the impeller and seawater pump must be working fine.
So, my questions are many:
- Any idea why the boat would behave this way? A friends boat did almost the exact same thing a while ago, but after a short while, it started back up and everything was fine. We wondered at the time if something had gotten sucked up into the seawater pump and jammed the impeller - and then finally worked its way through?
- I don't believe it should have anything to do with the situation, but could loading the port side of the boat down with ballast have anything to do with the start of the symptoms? I wondered if maybe some oily water in the bilge could have splashed up on the belt and made it slippery - leading to the initial slipping?
- If everything is working okay now - should I take it in to a mechanic and have him check it out. And if so, what should I ask him to check/ replace?
I have another unrelated question regarding transmission fluid level, but I'll ask that in a separate thread later.
Thanks,
Jared
Mischief Managed
Re: Serpentine belt not moving - lots of squealing
First off: You need to remove the pump, open it up and rebuild it, regardless of any other endeavors. That's the only way you'll know it's good.
I suspect you had some sort of blockage on the water inlet. Plastic shopping bags are really good for this sort of thing. Once the seawater pump ran dry for a few moments, it overheated and seized up. The tow back to the ramp likely dislodged whatever was blocking the water inlet and gave the pump enough time to cool down. The impeller is quite likely shot though.
JustJason
How could you possibly be in a bad mood over that??? I mean, your boats obviously been trying to tell you that something is wrong and you not only chose to ignore it, you tried to quiet it with a bar of soap.
R/R your water pump before you fry your new belt.
and use a wire brush or something to get that soap off of your pullys.
jabberw0cky
Thanks, that makes perfect sense! I'll get the pump looked at, and I'll double check the water inlet to make sure there's nothing lingering there that could prevent water flow.
jabberw0cky
Thanks captJason, I'll clean off the pulleys. I've been trying to figure out what was causing the noise before resorting to the bar of soap (pulled alternator and had it checked under load at a shop, replaced the Water pump). Finally using the bar of soap quieted things down, so I knew it was the belt making the noise, hence the purchase of a new belt.
I think the belt noise from before and the issue with the belt not moving at all last night are unrelated. I think Mischief Managed's theory of what happened fits the symptoms. I think I'll get the pump checked out and get the impeller replaced. Aside from that, hopefully the new belt will get rid of the intermittent noise we were getting before.
Thanks
JustJason
so the water pump was replaced already? and your still having the noise????
MikDee
Banned
Soap is not an issue Jason, it is an old age remedy for a squeaky belt,,, prob before your time, ;) don't worry, it will wear off by itself, yes I'd say check out your seawater pump, IMO something got caught in it tempoarily.
JustJason
nope not before my time... crayons or candles work well to. All 3 work well if your a woodworker for driving screws as well....
All i'm saying is put away the band aide box and fix the problem.
jabberw0cky
Yes, replaced the water pump (regular water pump above the crankshaft pulley, not the seawater pump) about 3 weeks ago. At that point I thought the noise we were hearing was a bearing going out on one of the pulleys, and using a stethoscope it appeared that the noise was coming from or near the water pump pulley. So replaced that, but still had the intermittent sound coming from it even after that. That's when a friend mentioned that it might just be the belt making the noise, and he suggested the soap/crayon trick. Tried it during a noisy episode and it quieted right down. So I purchased a new belt to install but hadn't gotten a chance to do it before the issue we experienced last night.
So anyway, now the new belt is on, but I won't have a chance to see if that takes away the noise until after I've replaced the impeller, etc. and get it out again. At least when I was back at the dock and started the engine back up at that point and put it on the trailer - the belt was nice and quiet. Though in the past it's been intermittent, so I'm not certain it has resolved the issue until I have a chance to have it out for a while.
Windykid
If you had a lazer thermometer you could tell which part is heating and locking quickly!
Ayuh,.... I Completely Agree with the Capt.......
I have No Doubt the Problem has been the same, right along....
Belts don't Squeal for no reason at all,....If it got So Bad that Only the crankshaft was turning,.....
I'd be tearing into Everything that's mounted on the front of that motor,+ getting to the bottom of it.....
Btw,.....
Lava works Much Better than any other soap or wax,....
It's loaded with Sand......;)
Coors
Btw,.....
Bondo, how would you know that?
Ayuh,....
I have a Doctorate in Common Sense,+ another in Creative Engineering.....;)
