SENDING WIRE FOR TRIM GAUGE
SEGER
I have a 1990 pro 90hp evinrude on a 28' suntracker party hut. The trim sending unit was on the motor but no gauge inside. the instructions that came with the gauge said to hook up the purple wire and the brown&white wire to the gauge but i don't have a brown&white wire, just a brown wire. that brown wire goes to a alarm There is a black wire with brown stripe and a brown wire under the dash. could not get it to work with those wires.
clanton
Re: SENDING WIRE FOR TRIM GAUGE
Start at the engine, locate sender, trace wire. This wire was in the T/T harness, which has a red/purple stripe, blue/white stripe, green/white stripe, tan/white stripe, black. The purple(power supply for gauge comes from ignition switch. The tan/white stripe, and black is for the gauge.
