sending unit
is a sending unit as easy as it looks to replace-- I see five screws and two wires/actualy 3 wires one wire is connected to another before it connectsto the sending unit. I assume all you have to do is pull one unit out and drop in the other--but that sounds to easy is there anything I should look out for--or any instuctions Thanks
tylerin
Re: sending unit
As I told you before yes it is quite simple but most replacement sending units are universal. Remove wires,remove 5 screws. you will most likely have to cut the new float arm on the new sending unit. sending unit will come with a detailed instuctions
Re: sending unit
thanks tylerin I think the one I saw was adjustable from 4" to 24" I guess I will find out
