This engine is driving me nuts. It's a 1965 75HP Evinrude StarFlite with electric shift. It would randomly die on me which I traced back to a bad ignition wire. Then a point went bad. I finally got it running and took it on the water only to have the throttle cable break. Before the cable broke I was able to get it to open up and go.<br /><br />That brings me to my current problem, while at full throttle the motor would occassionaly act like it was shifted out of gear into neutral, the boat would slow and the engine would rev higher but then after a second it would jump back into gear and everything was fine. Then awhile later it would happen again. I didn't hear any clunk or grinding.<br /><br />Since it's an electric shift and I've already had bad wires, could this be caused by a bad wire that just occassionally shorts out?<br /><br />Also I have water getting into the lower unit. Could the water mixed in with the gear oil be the cause?<br /><br />I've read that it could be the clutch dogs slipping but from what I've read there should have been a clunk or grinding as the clutch was slipping.<br /><br />Any help would be appreciated.
