I have a 1984 Johnson 70hp that was finally working and while out fishing it seized up on me. At first it started hesitating like it was not getting enought fuel(not the problem) but then when I put it in neutral it stopped abruptly. I pulled the top off and found I could not turn the flywheel clockwise but with much effort could counterclockwise. After several rotations counterclockwise(felt like it was unscrewing)I found I could rotate it both ways. Anyway, the engine starts but while its idling there is a "clunking" sound. Is this a blown rod and if it is how hard is it to fix, or even worth it for a 20 year old engine.<br />Thanks in advance<br />Martin in NJ
