I have a 1 yr old SEI 116, which is a basic Alpha 1 Gen 2 outdrive. I've put close to 40hrs on this outdrive since May. When I changed the gear lube, the old lube came out Black. I put the recommended green high performance gear lube in it before the season. Is this black color normal with 40hrs of use?
This is a conversion kit for an OMC cobra. No problems with the outdrive so far.
