My first year to have this boat, previous owner did away with the vro, I've been going through replacing what I can, tank,hose, impeller, fuel pump, fuel filter, plugs, steering cable, the fuel pump was what was recommended when I looked up the replacement, I am pushing in on the switch a couple of times, cranks right up, sounds good, starts to sound like it's about to die and push in again, runs a while but still dies, raising the throttle helps but still runs a while and dies, I've got a opening a month from now to have it looked at, just hoping for a miracle before then, thank you very much for the input, there's a couple of things that I can check
