Re: See Pics Leaking seam between lower unit to upper
The pics do not show any flow out the ports (series of holes/slots) at the Cav plate? That spray looks excessive. water does seem, and at times flow at that seem, but never seen one "spray" out that far. If it is still doing that, its wierd. If your cooling ok, got prop flow, and some out those holes---You might try a bit of indian shellack at that seam when apart. I do that to avoid the exhaust "stains" on the white housing.
But spraying out that far isnt normal unless the mating surfaces are in bad shape and have gouges/channels to let the water fly out.
