mercury_ke4
Thread starter- Joined
- Nov 13, 2007
- 2
Fuel shut off valve assembly on on bottom of Sears Waterwitch fuel tank is just spinning, cannot remove from tank. It threads into a disk which is attached to bottom of fuel tank, this disk turns but cannot remove from tank. Disk is about 1/4" thick and round.
Seems there must be a fastener inside the fuel tank holding the disk, which is now loose. Any ideas on how to remove? I could use a vise grip to hold the disk and then unscrew the fuel valve from it, but the disk now seems loose and may leak.
