Sears Ted Williams Eska Shift Question
tim_k
Eska experts: I have 2 project Ted Williams motors - not running yet - that don't seem to have a neutral. I move the shift lever to neutral and pull the rope, the prop still spins. These are oldies with no reverse gear. The lever apparently connects to a clutch dog at the bottom of the power head. Anyone run into this before and can suggest a fix?
CATransplant
Re: Sears Ted Williams Eska Shift Question
Model numbers, please. There are a lot of Ted Williams models, and we don't know which one you're talking about.
steelespike
As I understand it there is a spring loaded clutch.It corrodes and stops working.Sometimes ingaged others disingaged.Unless the motor is working perfectly I woudn't invest money or much time in the clutch. I think most just modify it so it is all ways ingaged.
tim_k
CATransplant, I'm kinda bummed, because neither of these has a legible model #, beyond the 217... Should I be able to find the model number anywhere other than the info plate on the transom clamp? It's nice that the old OMCs post it in two locations.
steelespike, the spring loading makes sense. The parts diagram for what looks like a very similar motor (Eska 1747C) just shows a clutch assembly, but I couldn't figure out how it worked. I think I'll take your advice and see how well I can get them to run before deciding what to do about the shift issue.
Thank you both for your input.
Richard2725
Does anyone have an idea as to what the gap setting wouyld be on hte spark plug, please? Any other information would also be appreciated.
Thanks.
M
mrcrabs
Guest
Hello Richard, You really need to start your own thread and give us your model no. so you can get an accurate answer,
Richard2725
Sorry, this is all new to me. How do I start my own thread, please? I'll go from there. My model is 217-59672.
Thanks.
