Outboard Obsession
Thread starter- Joined
- May 25, 2015
- 5
Although I'm new to this Forum, I've been working on outboards for some time. I recently became the owner of a Sears Game Fisher Model 217-58870, which if correct is a 1972 7hp. single cylinder. This motor looks to be in pretty decent shape, good compression, good spark, fairly clean carb, and so on. Two things I'd like to address before I light a fire in it. First is that the clutch doesn't seem to disengage, and the lever doesn't seem to do anything other than stop the throttle lever in the neutral position. the other item is to check out the water pump. Here lies my problem, after removing the bolts there is a slight gap between the power head and mid section, but I can't separate the two. Also when I remover the bolt and nut from the lower unit, it wouldn't separate either. I have tried gentle prying on these parts, but I don't want to damage anything. I can't see anything else to remove to get these parts to separate, so any help or ideas would be greatly appreciated.
