sears/force engine troubles
jwbanks
hey guys i have a sears 15hp outboard which i understand is the same as a 15hp force
m#225581506
s#oeo74491
just got it on a boat i bought dont know anything about it
tried to start it after putting in new fuel and doesnt look like im getting any spark
any ideas and any info bout the motor or things to look out for would be app.
thanks jason
steelespike
Re: sears/force engine troubles
The motor may have a kill switch with a safety lanyard.If it isn't ingaged you won't have spark.These are usually on or near the tiller.
If the motor sat for a long time you may have to go through the fuel system from tank to carb with careful attention to cleaning.Be sure the fuel connector is connected properly and the vent on the tank is open.
If you don't know the age of the impeller it should be changed.
Frank Acampora
Don't know about your specific engine but some of them had a kill switch built in under the flywheel. When the throttle handle was turned past a certain point, the engine shut off. To start, be sure the twist grip is in the START position. Also, some engines had a manual push button kill switch right on the front. If yours has one of these, be sure the wires going to it are not corroded or shorted. If everything else is in order, you need to pull the flywheel and clean and set the points. Check the condensers while you are at it to see that there are no rubbed and shorted wires. Or replace both points and both condensers--about 36 bucks.
