TwoBallScrewBall
- Sep 14, 2003
- 1,695
I moved my engine (200hp evinrude) up on the transom, and I want to reseal the bolt holes before I put it in the water. My plan is to remove one bolt at a time, fill the hole with 5200 (I bought the caulk-gun size tube) then reinstall bolt. Is this sufficient? Any better way to do it? I don't want to rot my transom out. <br /><br />Also what's a good torque value for these bolts. I have an air impact gun, should this tighten them enough? Or should I stick to a spec with a torque wrench?<br /><br />Thanks!!!!!!!!!!
