Sealing ring collar and spacer
Spin 53
Hi, Everyone . I've got a1985 125 force
while doing my Impeller change, painting the house , looking for a lost dog,
and everything else ..I seem to have( lost ) misplaced the sealingring,rubber coller and spacer that go on the end of the drive shaft. Is it possiable to run the motor with out them installed? thanks Spin.
Frank Acampora
Re: Sealing ring collar and spacer
Yeah! engine will run fine without them BUT they keep moistureout of the crankshaft (maybe) and prevent the drive shaft from getting stuck in the crank. Use anti seize on the splines of the drive shaft and order the collar and ring at your convenience.
Spin 53
Thanks for the Info. I did order replacement parts, I just didn't know if it was a major part of the cooling system....
Thanks Spin
