Sealing a Thru Hull Transducer
barthel
Evening all,
I am replacing a thru hull transducer for my boat. The old one came out OK, but I had a question about the new one. When I install it, would it be better to use 3M 4200 (semi-permanent) or 3M 5200 (permanent) sealant?
Thanks
Bob_VT
Re: Sealing a Thru Hull Transducer
Either one will work. 4200 is a bit easier to remove and the 5200 is more of an adhesive and permanent but either will work.
barthel
Thanks Bob.
Wasn't sure if 4200 would be OK, although that's what I wanted to use just in case it ever had to come back out.
