Sealegs on tritoons
Pontoonfamily
Anyone have sealegs on their tritoon ? How do you like them ? Would appreciate your thoughts as we are considering getting them on our 23ft Landau
H20Rat
Re: Sealegs on tritoons
can't speak for the tritoon portion, but my neighbors have them on a standard pontoon... Expensive option but they love them! They keep the pontoon in the water almost the entire season.
Slip Away
They make a nice volleyball court too.
Bamaman1
They're great things, but add about 500 lbs. to the weight of the boat. Sometimes they'll drag a little when at cruising speeds.
It all depends on the lake you're in and how you park your boat. The bottom needs to be relatively flat and shallow where the boat's parked.
I don't know if I'd want to leave my boat sitting on the legs if I wasn't close around.
H20Rat
The lake I'm on gets some fairly serious wind blown chop, and as long as the pontoon is fairly close to shore and the sealegs are all the way extended, the pontoons are fine. The ones that get in trouble are the ones that aren't high enough, and the waves are able to start floating the logs.
Pontoonfamily
Would the make of tritoon make a diff as to how the sealegs perform?
