Tested a Yamaha Reliance 13,75 X 19 today on my Yamaha F150. Normally run a Turbo 1 14,25 X 19. One thing that surprised me was that these two visually quite different props performed almost the same on my boat. Same top-speed 49 mph, same WOT 5900 rpm, same fuel consumption and rpms at typical cruising speeds for me 28-38 mph, same hole shot times. Maybe the T1 was a bit lower on fuel at cruising and maybe the Reliance had a bit faster hole shot but that is both within the margin of error. The Reliance had a smoother sound from the engine at very low planning speeds.
When I first run the Reliance without a timer I was convinced the Reliance was slower out of the hole due to a smoother and more quieter acceleration than with the T1. But the timer showed that they were equally fast or the Reliance maybe a tad faster.
The Reliance have no vent holes but the T1 has. I suspect that the smoother low speed planning speeds and smoother acceleration of the Reliance is beacuse it lacks the vent holes. I now want to seal off the vent holes of the T1 to see what happens.
So long story, short question. How do I seal off the vent holes? I am interested in a quick way for testing and a more permanent way if it shows to be a good thing to do.
