seaking 5hp runs rough
betzingj
Any help you can give would be great! Thank you in advance. I have a 1980 Clinton Seaking. It idols pretty well but when I took it out it spit and sputtered. I thought I cleaned the carb really well. Ideas?
Also, any ideas where I can get a rebuld kit for the carb?
How do I i.d. the carb and find part number?
I made a new gasket to go between the carb and the engine body because I thought it might be sucking air. I pulled and checked all the jets I could find. I set the float as best I could. I ran the bowl scew in all the way and backed it out 1.5 turns; same with the mixture screw. Still, when I put it in gear and try to run it up, it dies or almost dies.
Please help/
JB
Re: seaking 5hp runs rough
Try eskaman.com
Lodgepole
Be sure your fuel is good and has proper mix. See that screen at fuel line in fuel tank is clean. Next check points condition and gap. I think .020. Condencer could be bad as well as plug or coil. Plug gap should be .030. May be a trial and error deal.
pellasaws
check your gas to see if you got water in it,the gas now days will not last over 2 months,if that aint it your low speed jet needs to be open up some,then there is the eskaman2008 for parts
betzingj
Thanks guys! I appreciate your time.
Progress:
I checked the points and they were clean and gapped properly. Gas is new and mixed 24:1. Screen is non existant. Fuel lines have been replaced.
Questions:
I ordered a carb kit and it's on the way. Does anyone know the initial settings for the float, bowl needle, and air fuel mixture screw?
The mystery continues.
