I just took the bottom half off an outboard for the very first time to prepare for a new impeller! I've read a lot about the process so things were where I expected, but I was surprised to find the cavity that the gearchange column had some black grease and a little water in there. Then I realised that there is a water inlet just above the prop and it looks like that might be where the cooling water enters the leg? So is that what should be in there or do I have a problem? When I've done the impeller should I be packing any grease in that area before I close it up?
Anyhoo, the screws holding down the impeller housing were tight on so I've left them soaking in WD40 for a while...
