Re: Seafoam & fuel lines
Used at the proper ratio, there should be no problem. If used as a decarb treatment with the separate tank with a much higher mixture, there could be some problems. Id be sure to run regular fuel through as soon as I was done with the decarb. I poured some other brand of fuel stablizer into a plastic pour cup one time, it dissoved the plastic. Must be some caustic stuff.
