chadchurchill
- Aug 24, 2003
- 59
From reading the seafoam deepcreep can it seems as though this stuff can be used as starting fluid. I've been told not to use starter fluid in a 2 cycle motor, but with the seafoam having a lubricating property could it be used safely. Also could you remove the spark plugs and spray it directly into the cylinders?
