seadoo/ Rotaxengine case question?
goldhunter_2
OK admittedly I am a Bahama person :) so this is pretty embarrassing to even have to ask BUT here goes anyway.....
I picked up a 95 TX today ( was looking for some parts as ever thing I have is Yamaha so this worked out) anyway i know some of the older gets'' had 580 & 650 cases then they moved u to I thought 787/800 case but the guy thinks he was told it is a 720 by the former inhuman....:mad:
Dint' rot ax cases have palate or something some where to ID the case ? where the heck is it?????
goldhunter_2
Re: seadoo/ Rotaxengine case question?
ok not sure I like the spell check it changed teh G T X to TX and gets and R O T A X to rot ax
goldhunter_2
the hull ID shows it as a 95 , I am not sure if that is a orginal engine but form what I have found those hulls had 650,657,720,787,800. I beleive for the lower Case casting number stamped in the bottom case #8810660 it is a 720
the sticker plate that I am used to on the flywheel cover is gone I know there should ave been some way to cross refference the casting numbers, I just didn't have that info source
Oh, yes this was a dual carb (46) that is one of the parts I wanted and one of the reasons I bought this ski
thanks for the reply
