Re: SeaDoo repair
As long as you are satisfied thats what counts, I posted a bit on pwc central about getting a second opinion, true story, I was building some custom fork extensions for a fork lift to allow my used jet ski parts guy to lift skies from the rear to put them in racks, while I was at his warehouse he showed me a ski that he purchased from a local repair shop for 80 dollars, he said the shop obtained it from a customer who did not wish to replace the engine as the engine was frozen up. This was not an expensive ski , the parts guy asked me to look at the engine and tell him what I thought, I turned the pto and said the engine is not frozen its the pump that is frozen,I told him to remove the pump and see for himself, so he did, the engine was fine, I am sure the shop believed the engine was frozen and told the customer who probably just gave them the ski rather than spend the money for a rebuilt engine, however a used pump would have only cost around 250 and is pretty simple to install. The parts guy sold the engine and made out pretty well,The guy who owned the jet ski and took it to get it fixed was the looser on that deal, it took me 30 seconds to see that the pump had gone bad and the engine was fine.it was a 94 or 95 xp with the old style aluminum pump, the pump housing had corroded and expanded around the impeller locking it in place, I took the pump apart and the drive shaft impeller shaft and impeller were all in good shape all it needed was a pump housing as the housing was totally trash, worst I have ever seen, actually deformed so bad the pump liner took the shape of the impeller , if the mechanic who looked at the ski had taken any time to actually check it out he couldn't miss what was wrong.and I know he really thought it was the engine or he never would have sold it to my friend for 80 dollars, so a second opinion would have been a good thing for the poor slob that gave his ski away.
