Hi i just received a seadoo 580 rings were stuck from sitting i tore it down have the rings unstuck good compression but i cant get any spark i have 2 91 seadoo 580s and was wondering if there was an easy way to test each part stator cdi coil i was going to take one of my other running skis apart and just swap in each part starting with the cdi then coil hoping its not the stator does anyone know an easy way to test those without swapping them into my other skis as i dont want to screw up a running ski also does anyone know what size that woodruff key is mine broke when i tore it down and i cant find one anywhere also there was alot of gunk and rust under the flywheel so i took off the metal covers that were on the flywheel to expose just the magnets would that cause a problem as for it not sparking also i have to motor out of the ski does it have to be plugged back into the switches on the ski to get spark i thought maybe that could be like in kill switch mode with out being hooked up any ideas here
