Sea Ray
rondavila
This 24' has sat for approx 5 yrs. Any suggestions on what to do before I try to start it. It has a Mercruiser 260 V8. I new to the world of boating .
nlain
Re: Sea Ray
I would first check the gas tank to be sure that good fuel is in it, no water in the bottom, no separation of gas and alcohol, etc. Change all fluids and filters, lube all grease fittings, you will need the maintenance manual for this to locate what needs lube and what type lube. After 5 years I would change the water pump impellar also. There is probably more but that is what comes to mind right now. Hope this helps.
