Sea Ray with MerCruiser MCM 4.3LX coupler temperature
Lansselot
Hello,
We burnt out the rubber of our engine coupler. Don't now why, checkt the alignment at the start of the season with my self made alignment tool and this looked oke. I now bought a real alignment tool to be sure.
Pulled the engine, replaced the coupler, front engine mount and rear engine mounting hardware.
Engine alignment was harder than I hoped to get it right, I'm planning to have our work checked by a professional this winter.
I checkt the temperature with a infrared temperature meter to check that it won't burn out again.
My question:
How hot can the coupler get without damage?
During a test the temperature remained around 60 degrees Celsius.
Thank you,
Sander
Scott06
Hello,
My question:
Thank you,
Sander
Never checked coupler temp but being on back of engine next to the exhaust I’d say 140 f / 60 c is fine
if you have relatively even witness marks in the grease don’t worry about it. When I did my repower I could not get the grease marks perfect, spent a bunch of time back and forth ….
drive slid on and has worked fine for 9 seasons 380 hrs and I do a ton of watersports towing with a full boat …
Lansselot
Thanks for your response. That gives me a little confidence that it will be okay. Of course I am a bit cautious since we have not been able to find out why the old one broke.
Scott06
Were you able to check alignment after the coupler blew?
99 % of the time if the alignment is good and there is no engine sagging due to transom or stringer rot, the coupler will last the life of the boat if greased.
I assume it is a somewhat older boat being a 4.3 LX ? might be worth drilling some holes in transom and stringers to make sure.
Is the alignment tool you made (assume turned on a lathe?) the correct dimensions?
