1979 Quartermasters
- May 30, 2009
- 505
Hey guys;
An update and a question,
First I removed the engine to investigate an oil leak. Leak appeaered to be coming from the pan. Changed the pan gasket.
Changed lower shift cable. Removed fuel tank, steam cleaned and preasure checked, all good.
Lowered engine into the bottom-less pit (all by myself, I might add), bolted her down. Checked the alignment and it was almost perfect. I will fine tune it later.
Now the question. In the picture with the arrows, I can't find the connecting wires for those ends. The wires are beige and black. They are coming out of the wiring harness behind the distributor. I have connected the shift assist, and the trim wires. Maybe if somebody knows what those wires might be for, it might help me locate the other ends. I put matching color zip ties on so I could easily match them up.
Here is a few pictures of the engine going in and the wires in question.
Thanks....
Ken
I ordered the Corsa Captain's Call exhaust for the Sea Ray. Will be shipped January 8th. Can't wait!!!
Thanks....
Ken
