Re: Sea Pro wash down wiring
without the pump, they may not have ran the wiring. if you can see a wire on the load side of the switch, trace it back as far as you can. also really look at the wires at the stern. you ay have to cut and test each one with a meter, turning the switch on and off to see when you found it. good luck-
