Sea Pro 195 F/S fuel tank size
b.mccall
Hey, does anyone know where I can find the size of the fuel tank on a 2000 Sea Pro 195 Fish/Ski? The oil injection system has failed and I'd like to just premix my fuel in the tank. Not knowing the size makes it difficult to know how much oil to start with on a full tank.
Alumarine
Welcome.
If you can get at the tank to measure it then you can google
"determine rectangular tank volume" to find the capacity.
Chris1956
Pull up any hatches and see if the fuel level sender is there. Look for a tag on the tank. If that doesn't get it, you may need to look under the console.
Alternatively, drain it into Jerry cans. Figure it to be about 40Gal.
b.mccall
Thanks @Chris1956. Not a bad idea as my fuel gauge doesn't read right anyhow. I'll check it out.
b.mccall
Welcome.
It appears the entire boat was built around the tank. I can't even see the tank under the floor.
nola mike
Empty it and refill. That will get you very close, although not close enough for me to trust with a premix. Now you know how much you added, so add the appropriate amount of oil. Going forward, just add your 16 oz to every 6 gallons or whatever.
