I recently purchase a used Great Lakes Special (16'0 1/2") which has a livewell under the Captains seat. It is an aluminum tank with an inlet through the bottom. It also has a standpipe in the bottom with a "T" about an inch from the floor of the well and an open top. The unit has been modified as the inlet has a length of tubing which comes through the inlet and goes up to an aerator along the top rim. I can't figure out how the drain works. As it is right now, the aerator switch turns on the pump which fills the well, but the drain doesn't work when the water goes over the top. It will actually overflow onto the deck. Does anyone know of a source for a diagram on the original installation? Or what I should do to retrofit? It only has the one pump for filling the well.<br /><br />All the best,<br /><br />Mick
