Sea King model year help
tids
I just received a Sea King outboard and need to figure out the year and what fuel/oil mixture to use. Model # is GG8960A and the Serial # is 75X671437. It has a 5 on the side cover so I assume it is a 5 horse.
steelespike
Re: Sea King model year help
You have a 57 5 hp based on the Gale 5D14. 5hp @4,000,8.84 cu.in..It shares many parts with the E/J 5.5hp.
tmcalavy
16:1 was the original recommended fuel mix, but you can go 24:1 with modern TCW-3 marine oil.
tids
one other question, there is a brass looking shaft coming through a hole in the cover on the shifter side. What is that for, did it have some kind of knob on it?
steelespike
If it has an intagral tank it is the gas shut off. It did have a little black squarish knob.
