Sea King K700 1107A no reverse
Galderan
I have a sea king, made by Clinton, K700 1107A, type 60 27270 R and I need a blow up of the parts so I can see where the problem might be. I shift and nothing happens. It is always in forward. Runs great other than that. Also, does anyone know where I can get parts?
Thanks for the help.
Tom @ Buzzard Bluff
Re: Sea King K700 1107A no reverse
If I read my Intertec L/U parts breakdown right you should have only forward and neutral but in that particular pic some of the parts are obviously mislabeled as fuel pump parts so I may be wrong. Reverse is obtained by spinning the motor 180 degrees. Try spinning your motor---if it turns 360 degrees you have no reverse gear.
