Sea King I.D.
Dkocak
I have a Clinton Engine Corp, SEA KING 7.5 HP.<br />Here's the data.<br />MODEL XTV 50575 B<br />SERIAL 1617108<br />TYPE K751 6106 A<br />It's got spark and I'm pretty sure it will run, once I resolve the carb problem. Leaks everywhere. Even the bowl is perforated with pin holes. Looks like corrosion. What I would like is the year it was made, and who's carb is on it. I need a carb rebuild kit, and I need a little more info to go on. Did Clinton Engine Corp. use a carb that would be still available?<br />Thanks,<br />Den
CATransplant
Re: Sea King I.D.
If you need a whole carb, which it sounds like, you can probably get a decent one from tcoutboard.com (www in front of that). It's a very common engine, and they'll have several in their stock.
Dkocak
Re: Sea King I.D.
Thanks CA Transplant...Gonna check it out right now! Hope I can return the favor one day.
