I also have a Sea King 5 from Ward.
I had it in the shop a few months back as it had sat around for 30 years or so...
Mech informed me hs installed a new impeller/cleaned carbs, etc.
- Engine starts on first pull, however, I see NO WATER leaving from ANY ports. There are 3 "chevron" shaped openings below the powerhead (as indicated in an above post) but I cannot tell if this is the water departure point I have ensured water entry points (suction) submerged during testing.
- Engine not reliable for more than a few minutes on setting other than idle, or very slow. Upon increasing throttle, engine misses (indicated by popping sound) and begins to stall out unless decrease in throttle immediately applied.
Do I need an new impeller? Or are there other exit posts for cooling water other than chevron-shaped louvres?
I ordered a manual today that will arrive in a few days -
Any thoughts?
Thanks in advance!
Scott
Any thoughts?
Thanks in advance!
Scott
